Login
YoutubeInstagramRSSGithubPatreonPrivacy
Fixt • © 2025
Updated: Mar 3, 2024—5 min read
First Local AI Model Specially trained to Control Home Assistant
Text Generation WebUIConfigure the Model List of Compatible ModelsHome 3B v3 GGUFHome 3B v2 GGUFHome 1B v2 GGUFLlama Conversation IntegrationConfigure Assistant How to get better resultsHow to Trigger Automations and Scripts
Sentinel Sight: Unleash the Full Power of AI Vigilance with Gemini Vision and Home Assistant
New version of the integration out now, it is now compatible with any other Open AI API compatible project
To install it on the same device as Home Assistant (CPU only)
To install it on you own PC (Windows/Mac/Linux/WSL)
Configure the Model
If you are using the Add-On, just click on the show Add-on button ↑, and then click on Open Web UI
If you are using the PC version, just open the web UI from the link in the console or just go to http://localhost:7860/ from the PC you installed it
If you want a simpler AI configuration using this same integration, take a look at my Ollama + Home Assistant Tutorial
Home 3B v3 GGUF
acon96/Home-3B-v3-GGUF
NameQuant methodBitsSizeMax RAM requiredUse Case
Home-3B-v3.q2_k.ggufQ2_K21.08 GB3.50 GBsmallest, significant quality loss - not recommended for most purposes
Home-3B-v3.q3_k_m.ggufQ3_K_M31.39 GB3.89 GBvery small, high quality loss
Home-3B-v3.q4_k_m.ggufQ4_K_M41.71 GB4.21 GBmedium, balanced quality - recommended
Home-3B-v3.q5_k_m.ggufQ5_K_M51.99 GB4.49 GBlarge, very low quality loss - recommended
Home-3B-v3.q8_0.ggufQ8_082.97 GB5.47 GBvery large, extremely low quality loss - not recommended
Home 3B v2 GGUF
acon96/Home-3B-v2-GGUF
home-3b-v2.q2_k.ggufQ2_K21.11 GB3.67 GBsmallest, significant quality loss - not recommended for most purposes
home-3b-v2.q3_k_m.ggufQ3_K_M31.43 GB3.98 GBvery small, high quality loss
home-3b-v2.q4_k_m.ggufQ4_K_M41.74 GB4.29 GBmedium, balanced quality - recommended
home-3b-v2.q5_k_m.ggufQ5_K_M52.00 GB4.57 GBlarge, very low quality loss - recommended
home-3b-v2.q8_0.ggufQ8_082.96 GB5.46 GBvery large, extremely low quality loss - not recommended
Home 1B v2 GGUF
acon96/Home-1B-v2-GGUF
NameQuant methodBitsSizeUse Case
home-1B-v2.q2_k.ggufQ2_K2582 MBsmallest, significant quality loss - not recommended for most purposes
home-1B-v2.q3_k_m.ggufQ3_K_M3742 MBvery small, high quality loss
home-1B-v2.q4_k_m.ggufQ4_K_M4894 GBmedium, balanced quality - recommended
home-1B-v2.q5_k_m.ggufQ5_K_M51.03 GBlarge, very low quality loss - recommended
home-1B-v2.q8_0.ggufQ8_081.51 GBvery large, extremely low quality loss - not recommended
The above RAM figures assume no GPU offloading. If layers are offloaded to the GPU, this will reduce RAM usage and use VRAM instead.
By acon96
My prompt
You are a helpful AI Assistant that controls the devices in a house. Complete the following task as instructed or answer the following question with the information provided only.
You can use any motion sensor to determine precense in a room.
For example: if binary_sensor.entrance_motion_sensor 'Entrance Motion Sensor' = on, then someone is at the entrance.
Current Time: {{ as_timestamp(now()) | timestamp_custom("%c %Z") }}
Service: {{ services }}
Devices:
{{ devices }}
Open your Home Assistant instance and show your helper entities.
You can use this button to go to the helpers page and create a input_boolean (Toggle) using the user interface .
